| Applies To | | |
| Product(s): | OpenPlant Modeler | |
| Version(s): | 08.11.09.XXX | |
| Environment: | Windows 7/8 (64 bit) | |
| Area: | Properties | |
| Subarea: | | |
| Original Author: | Harpreet Singh, Bentley Technical Support Group | |
This article will explain how the properties can be moved to another category using class editor tool. In this article, we will take DEVICE_TYPE_CODE property on STRAINER class as an example. this property is on general category by default as shown below.
Steps to Follow
- Open class editor and load OpenPlant_3D schema.
- Supplement it with OpenPlant_3D_Supplemental_Modeling & OpenPlant_3D_Supplemental_ModelingViews schemas.
- Go to STRAINER class and locate the DEVICE_TYPE_CODE property.
- Override the property by clicking Override button on the right side.
- Add Category custom attribute on the property.
- Change the location to OpenPlant_3D_Supplemental_ModelingViews schema.
- Add the values in Category custom attributes as shown below.
- Save the changes and re-open the DGN file in OpenPlant Modeler.
- Select the Strainer and check the property in element Info dialog.
Comments or Corrections?
