| Product(s): | OpenUtilities Substation CONNECT Edition | ||
| Version(s): | 10.00.XX.XX to 10.10.XX.XX | ||
| Environment: | NA | ||
| Area: | Component Feature | ||
| Subarea: | Device Cross-Reference |
The users may need to Turn On / Off the visibility of the Cross Reference Symbol / Text for Parent or Child symbols depending on the requirement. In this Wiki Article, we will see how the cross reference can be Turned On / Off.
1. Select the Symbol for which the Cross Reference needs to be turned On / Off.
2. After selecting the Symbols on the Command Ribbon new " Modify Component" ribbon will appear, select Show Cross-Reference options under the Settings.
| Original Author: | Satish Saptasagar |
