| Product(s): | AutoPLANT IsometricsĀ |
| Version(s): | All |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
AutoPLANT Isometrics is an intelligent isometric drawing application allowing either direct specification-driven isometric drawing creation or automatic extraction from a 3D model.
AutoPLANT Isometrics requires Autodesk AutoCAD 2004, 2005, 2006, 2007, or 2008 running on Microsoft Windows 2000 SP4 or later, Microsoft Windows XP Professional SP1A or later. The hardware requirements for AutoPLANT Isometrics is equivalent to the version of Autodesk AutoCAD that will be used and 1.5 gigs of hard drive space for the AutoPLANT install.
No, Isometrics allows direct isometric drawing creation as well as extraction from a 3D model.
Yes, the Auto-Iso feature automatically produces isometric drawings from an AutoPLANT Piping module..
Yes, individual components in the drawing contain data pertaining to the spec used to insert the component. Also included are line, service, area, and unit data.
Yes, the same specs are used for both programs.
No, there is no conversion from AutoPLANT Isometrics to AutoPLANT Piping.
Yes, AutoPLANT Isometrics requires a separate license from other AutoPLANT applications.
