| Applies To | | |
| Product(s): | OpenPlant Modeler | |
| Version(s): | 08.11.09.XXX | |
| Environment: | Windows 7/8 (64 bit) | |
| Area: | Component | |
| Subarea: | | |
| Original Author: | Harpreet Singh, Bentley Technical Support Group | |
In OpenPlant Modeler, by default threaded joints do not have any symbol to show the connection as shown below.
If user wants to show a weld symbol for verification purpose to determine the connection the below steps should be followed.
- Open class editor and load OpenPlant_3D schema.
- Supplement it with OpenPlant_3D_Supplemental_Modeling schema.
- Go to WELD class and right click on it and select 'Add Derived Class' from options as highlighted below.
- Name the new class say 'THREADED_CONNECTION'.
- Go to JOINT class in the schema and locate THREADED_JOINT in the joint map.
- Right click on Fastener field and select Add Element.
- Add THREADED_CONNECTION as shown in the Fastener [0] field.
- Set 'Is Fastener Spec Driven' field to FALSE.
- Save the changes and verify the result in OpenPlant Modeler.
communities.bentley.com/.../25475.how-to-place-multiple-welds-in-straight-piece-of-pipe-at-equal-distance
Comments or Corrections?
