| Product(s): | Power ProStructure V8i / ProConcrete | ||
| Version(s): | V8i | ||
| Area: | 2D Rebar | ||
| Subarea: | Reinforcement Labeling | ||
| Original Author: | Sandip Kar, Bentley Technical Support Group | ||
| Updated by: | Kemuel Jancorda, User Success Team |
In this document, we will guide you on how to check the available Presets for 2D Reinforcement Labeling.
The complete list of Presets of Labelling can be found in the below path. You can open it in notepad to view this.
For ProStructure CONNECT Edition : Drive:\ProgramData\Bentley\ProStructures CONNECT Edition\Configuration\WorkSpaces\<Localized Country>\Standards\ProStructures\Rebar\Detailing\ <Country>\presets.sys.
For Power ProStructure V8i : Drive:\ProgramData\Bentley\ProStructures V8i S8\WorkSpace\Rebar\projects\<Localized Country>\presets.sys.
This can also be found directly in the product itself. It can be found in RFeinforcement Labeling section and in that Presets. See the image below
