| Product(s): | AutoPLANT Equipment |
| Version(s): | XM, V8i |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
When a project is opened from AutoPLANT 2004 into either AutoPLANT XM or V8i, an error occurs when initializing either the Equipment or Import/Export menu.
ERROR DEBUG MODE Variable Is Not Defined In The Settings File Unable To Initialize Equipment Application
- Open the following file in notepad: ..\project name\config\config.ini
- Find the following section: [Equip.SysPref]
- Make sure the following four lines are in this section:
;// No user interface
DEBUG_MODE = 0
;// For forward compatability with FW. Not required now but for TOOLS #2485
DEBUG = 0 - Save and close.
- Open the model and load AUTOPLANT PIPING.
- Type in the following commands:
(at_pipingsystem_setvariable "DEBUG_MODE" "0")
(at_pipingsystem_setvariable "DEBUG" "0") - Save the model and now you can load Equipment.
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
