| Area: | Import/Export | ||
| Subarea: | Integrated Structural Model (ISM) | ||
Bentley’s Integrated Structural Modeling (ISM) is a technology for sharing structural engineering project information among structural modeling, analysis, design, drafting, and detailing applications. ISM is similar to Building Information Modeling (BIM), but focuses on the information that is important in the design, construction, and modification of the load bearing components of buildings, bridges, and other structures.
Please follow the below links for more information.
- Integrated Structural Modeling
- ProStructures Help: Integrated Structural Modeling
- OpenBuildings Designer Help: ISM (Integrated Structural Model)
Part-1: Interoperability Workflow between STAAD Pro and ProStructures (Part 1) | https://youtu.be/aviMLs8t1g8 |
Part-2: Interoperability Workflow between STAAD Pro and ProStructures (Part 2) | https://youtu.be/TgmluSax9go |
