| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Import/Export | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
While importing or exporting the STP file below error is displayed in OpenPlant Modeler.
This error is appearing because it is not able to find the path of the rose database as you can see below variable MS_ROSEDB is not defined in the configuration.
$(MS_DATA)\rose\database
