| Area: | |||
| Subarea: | 3D PDF Print | ||
In this wiki, we are going to learn how to print the 3D PDF in ProStructures CONNECT Edition.
1. Search “PDF” in Search Ribbon and click on the Print to PDF. Or go to the backstage File > Print > Print to PDF.
2. In the Print dialog, check the box for Print to 3D and then click on the Print to File button.
3. The dialog Save Print As open ups, here browse the required path and give a required pdf file name then click on the Save button.
In this way, we can print 3D PDF in the ProStructures CONNECT Edition.
communities.bentley.com/.../how-to-print-3d-pdf-which-includes-the-element-properties-in-it
