Quickly Navigate To Part Number Records in Promis.e Connect
 Product(s):Promis.e, Bentley Substation
 Version(s):through 08.11.13.140
 Environment:N/A
 Area:Component Management
 Subarea:Parts Database
Quickly bring up the record for a part number in Parts Database Manager while viewing a device that uses the part number on a project page with the following process.
  1. Open a page containing symbols for a device which has at least one part number assigned to it.
  2. Turn on the display of part numbers at symbols by selecting [[Display Part Numbers]].
  3. Right click a part number on the page and select Edit Part Number (in versions prior to V8i SELECTseries 5, select Navigate).
This will open the [[Parts Database Manager]] dialog and display the record for that part number.
Remember, if any changes are made to the part number record, use the Show Differences button on the upper right of the Parts Database Manager dialog to update the project with the new data.
Note: Part numbers are suppressed at child symbols by default.  To change this, select [[Options]] > Project Options > Part Number Settings and clear the check box for the "Suppress Part Numbers On Child Symbol" option on the Display tab.  In V8i SELECTseries 6 and earlier, select [[Options]] > Project Options > Display Formats and clear the check box for the "Suppress Part Numbers On Child Symbol" option on the Part Number tab.
[[Parts database changes not reflected in project]]
[[Quick Filtering In The Parts Database Manager]]
 Original Author:Matt_P
