| 364829 | Check feasibility : Substation SQL Project DB in Azure |
| 517937 | [Device Usage][SUBID] improve Duplicate Device ID EDC, add option allowing user select existing Duplicated Device to link with |
| 484445 | [Repeating object] It should support the repeating placement with Side and ISO views |
| 494199 | [Merge Into Master] Add Maintain Options for: Device/Wire Link/Wire Numbers/Terminal Numbers and exclude Title Block/Page Format objects |
| 586775 | [DB version] Long Term: Add Sub-version for Substation DB version. |
| 597693 | [Edit Tags] Open Appropriate Substation editing dialog when user double clicks on a Tag or uses Edit Tag |
| 620998 | [BOM Manager][Edit] allow user to select specific data fields and field order to show in Part Number Grouping |
| 629023 | [Edit Tag]Double click a wire number, it should popup Edit Wires dialog. |
| 630319 | [Seed File] The Page folder and its dgn files in the Templates folder is wrong. |
| 599887 | [Performance][Data Manager][Device ID] when user saves changes after a Device ID replacement, save operation is extremely slow |
| 600017 | [ProjectWise Integration] [Multi Users] Multi Users' projects always prompt missing project Option.xml and Substation_Workspace.cfg files with PW |
| 600483 | [Performance][Data Manager][Symbol Text] when user saves changes after a Symbol Text replacement, save operation is extremely slow |
| 600544 | [Performance][Data Manager][Page Description] when user saves changes after Page Description replacement, save operation is extremely slow |
| 603976 | [Symbol Creation][Catalog Cache Not Updated] after user saves symbol and attempts to place new symbol message "Can not find symbol named 'xxxxxxxxx' in catalogs" is displayed |
| 604010 | [Project Manager][ProjectWise Integration] User Name value remains after closing page when ProjectWise Document Security on page is set to exclude Document & File Write permissions |
| 604390 | [Part Number]Error appears when right click on some symbols to select Part Number in demo project SUBSTATION_SAMPLE_ANSI-IEEE.Prj |
| 611089 | [BOM Manager] [Performance] Assign Balloon No to one part number with a large quantity will be slow |
| 611103 | [BOM Manager][Performance] Set parts under Work Order >Unassigned items to Group by device will be slow |
| 611220 | [Replace Symbol Text][Performance] It takes more than 3m to replace 6 symbols' symbol text on the active page |
| 613025 | [BOM Manager][Performance] Load data by Work order : It takes long time to add part to an existed device in BOM Manager |
| 613032 | [BOM Manager][Performance] Load data by BOM Document: It takes a long time to add part number to an existed device in BOM Manager |
| 616978 | [Reports][BOM_Substation_Qty_WOBOM] SQL query invalid error appears when user attempts to run report |
| 617944 | [Modify Text][Line Spacing] after inserting Multi-Line text, Line Spacing Value for existing Text Style changes |
| 587495 | [ProjectWise Integration][Raster File] Close Page does not prompt user to checkin TIF / raster file |
| 589750 | [Place Labels] Place Label and label tag will crash |
| 591678 | [MicroStation Mode] It's crashed while Copy and Paste the attached raster image |
| 592391 | [PW Explorer Plug in] After renaming a project name from PW Explorer, the project will be disabled. |
| 595821 | [Modify Page]Change to Title Block value and/or Page format applied to user defined Model instead of Default Model |
| 499499 | [Insert Objects] It will list the part UI of Placement Option dialog for the first time |
| 512588 | [Work Order Manager] When an existing work order is created, Import Work Order dialog will pop up and cannot be closed |
| 518525 | [Delete Reference Point] Correct the Delete Reference Point dialog name |
| 541386 | [PW]It popups Unhandled Error and “Orange X” in Project Manager if the checkouted ProjectOptions.XML is deleted from dms folder. |
| 549183 | [ProjectWise Integration][Project Options][Work Area Type] values shown in Project/Work Area pulldown are incorrect |
| 553093 | [ProjectWise Integration][Copy Page] It will report error when copy page that has been created new version when check in |
| 572843 | [Azure DB]Cannot create a new project with an existing Azure SQL database. |
| 572845 | [Azure DB]Cannot restore a project with an existing Azure SQL database. |
| 583282 | [Insert Linear object] The hook point will fly out of the linear object |
| 585875 | [Wiring Diagram Settings]It cannot select the cross reference type symbol and if only change the symbol name, it cannot be used in the project. |
| 456561 | [Performance] [Insert Symbol] The Memory is not released after closing the Insert Symbol dialog |
| 483756 | [Display Connection Point Text] The level of some cross-reference text is incorrect ECT_DGRM_CPNT_TEXT |
| 650393 | [Performance][Data Manager] Add message for Logical field tab to prompt Deivce Tags will be updated. |
| 650700 | [Repeating Object] Update repeating object will crash |
| 662013 | [Installer] Substation U11/Promis.e U9 should update Installer UI that was changed in MicroStation U16. |
| 673884 | [Merge Into Master] unhandled errors when merging page from different project different database |
| 674666 | [Copy/Paste] unhandled error appears when copying objects from a referenced page belonging to a different project database |
| 676137 | [PW][drawing set subfolder]Most of the ribbon menu cannot work in schematic/Panel layout/Wiring diagram mode page when the project is using the sub folder feature. |
| 676567 | [Copy/Paste]It popups unexpected dialog when copy/paste symbols without Installation and Location. |
| 609800 | [Performance] Open page with reference(s) is slow. |
| 609802 | [Performance] Delete MicroStation graphics and texts is too slow in some pages. |
| 610324 | [Data Manager][ Wire Number][Performance] Replace Wire Tag, the save operation after replace dlls is slower than before them. |
| 611188 | [Insert Symbol By Device ID][Performance] It takes about 4 mins to Search Devices for the first time after launch Substation |
| 611194 | [PLC Settings][Performance][PW] It takes about 5 mins to close Options after making settings in PLC Settings and click OK |
| 611199 | [Edit DrawingSet Description][Performance][PW] It takes about 5 mins to Save the values for Edited DrawingSet Description |
| 611888 | [BOM Mananger][Performance]Drag part with large quantity to other BOM/Revison/Work Order, it is too slow. |
| 612698 | [Insert Symbol By Device ID][Performance] It takes very long time to open dialog |
| 612771 | [Project Options][PLC Settings][Performance][PW] Project Options Save takes long time after user attaches PLC .xls file to project |
| 613678 | [Insert Symbol by Device ID][PW][Performance]Insert Child symbol or panel layout symbol in the drawing by Insert Symbol by Device ID, it is too slow. |
| 613684 | [Performance][PW]Save Drawing Set, Installation, Location descriptions is too slow. |
| 614354 | [Options][Performance][PW] It takes more time to save Project options settings by clicking OK than in local WorkSpace |
| 573393 | [BOM Manager] BOM Manager refresh does not update the Balloon number from design file equipment's |
| 585861 | [Create Symbol]The first cross reference text should be Cross Reference Text 001. |
| 595231 | [Copy Reference file]Copy/Paste reference file from different project, it only popup the Paste Options dialog one time. |
| 617223 | [Edit Tags]There are a duplicate blank between the “device’s” and “Part”. |
| 617458 | [Edit tags]The Show Plain Text cannot be enabled when double clicking the general symbol text of symbol: DSFU. |
| 617995 | [Edit Tags]Double click Wire Link ID/Wire Link Cross reference/Terminal Number, the popup dialog is not the expected. |
| 505280 | [Insert Symbol By Name] Error about CacheFile() Method appears while clicking catalogs under Components Center one by one quickly |
| 605804 | [Family on the Fly] The description in Device Family need to update |
| 577876 | [BOM Manager] Part Number not maintained if assigned from BOM Manager for equipment placed in design file by name |
| 608476 | [Select Part Number dialog] The column chooser options is not accessible for the Select Part Number Dialog |
| 626680 | [PW Integration][Title Block Designer] When existing Title Block is modified and saved the changes are not saved into Catalog and the Title Block DGN is checked out |
| 503797 | [Catalog Manager]Rebuild catalog, it popups error dialog "field is too small" |
| 595084 | [Title Block Manager]Modify a title block used in a page, then modify the description of the page, the page’s title block is changed though user does not replace the title block. |
| 542521 | [Import] Crashes when importing *.shp file |
| 543601 | [Reality Modelling] Reality Modelling Ribbon is not available in OU Substation MicroStation Mode |
| 556107 | [Copy Project]For BOM Manager Non-Coded parts data not maintained after a Project is copied |
| 605043 | [New Page][Sheet Model]The page information cannot display in the title block if creating the page with the toggle place Title Block in the sheet model is turned on. |
| 509685 | [New Project] An error appears when connect to old database,select No in Database Version and click Cancel in New Project |
| 537930 | [System Options] The user is getting error message when accessing Systems Options when "UniqueBalloonNumberPerNameplate" is set to TRUE |
| 576971 | [New Project] An error appears when create a project under path defined by Add a network location |
| 668124 | [Project Manager]A strange node generated under project after run Project Publisher, Shortest Distance, Backup Project with Create Project Catalog turned ON and restore it, then Refresh Explorer |
| 622155 | [PW Integration][Place Balloon] The user is not able to place balloon for projects in PW which have project pages saved in Drawing Set Sub folder |
| 583895 | [Wiring Diagram Settings]The Jumper prefix and suffix cannot display if all the four items set as Always. |
| 535464 | [Auto Wire Number]Open demo project, and auto wire number the project, it popups error dialog. |
| 503721 | [BOM Manager][Export BOM Data]The export BOM Data should sort according the data in the BOM Manager dialog. |
| 629022 | [BOM Manager]Change the part number in the Edit dialog, the mapped field value cannot get from the Part Database on time. |
| 562365 | In select part database dialog box 'hide this column ' is not appearing |
| 359133 | Lock Project: User name displayed in Project Manager even after page is closed and Promis.e relaunched |
| 414443 | Modify Page is done is done to change Page Descriptions on Title Block Fit view is done when changes are saved |
| 574301 | [Modify Text] Line spacing changes after user modifies multi-line text value |
| 670142 | [Configuration Assignment Utility] The user is getting .net error when trying to login to a database when using Configuration Assignment Utility |
| 609600 | [Copy Symbol] Using Ctrl + C and then pasting the symbol does not span the connection point of symbol being pasted on grid |
| 545261 | [Move Wire] When a wire is moved the Wire Number / Tag gets deleted |
| 533964 | [New Project][Modify Project] name column not updated with Project Descriptions from selected project options file |
| 595507 | [PLC Symbol] In symbol creation when updating existing Attributes by placing new once, the updates are not saved for user custom symbol |
| 603272 | [Replace Family] The is user is not able to replace family from Device Properties with Connection Points details maintained |
| 581513 | [Terminal Placement] When placing multiple terminals on wire with wire tags alert message "The Wire Number is moved to another Potential, do you want to delete it ?" pops up |
| 562446 | Project Publisher is not working sequence |
| 504749 | Error while importing dwg Title block |
| 442635 | Error while adding record in partdatabase |
