| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Component | ||
| Subarea: | - | ||
| Original Author: | Harpreet Singh, Bentley Technical Support Group |
In this wiki article we will discuss how support tag can be customized by including several properties in the tag. We will take example of three properties UNIT, SERVICE & LINENUMBER to build a tag for support.
Case II: How to pull the tag from adjoining support
There may be a case where primary support is connected to another support and same tag has to be applied to it. For example, DIRECTIONAL_SUPPORT_GUIDE is connected to TEE_SHOE as shown below:
Note: For existing support, which have been placed prior to this modification will not update the tag automatically. To force the reevaluation of the tag,
