| Area: | |||
| Subarea: | 3D PDF Print | ||
In this wiki, we are going to learn how to print the 3D PDF which includes the element properties in it.
1. Search “PDF” in Search Ribbon and click on the Print to PDF. Or go to the backstage File > Print > Print to PDF.
2. In the Print dialog, check the box for Print to 3D and go to the Settings > PDF Property Publishing. Now, the Print – PDF Property Publishing dialog opens, here select All in the Include Properties field and click on the OK button. Then finally click on the Print to File button.
3. The dialog Save Print As open ups, here browse the required path and give a required pdf file name then click on the Save button.
4. Open the printed 3D PDF in PDF Viewer to see the 3D model with the properties of the elements.
In this way, we can print 3D PDF with the properties of the elements in ProStructures CONNECT Edition.
