| Product(s): | OpenPlant Orthographics Manager | ||
| Version(s): | V8i | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Bentley Product Advantage Group | ||
OpenPlant Orthographics Manager V8i automates the extraction and production of high-quality general arrangement plant drawings from a 3D model. Orthographics Manager works for OpenPlant Modeler with increased productivity and cost saving in drafting, which allows engineers to focus on their design job.
To install OpenPlant Orthographics Manager, user should have Open Plant Modeler downloaded.
Yes, more than one view definition files (VAD) can be selected to be processed in a single execution command. This multiple selection of different files reduces the drawing output time for large number of drawings
Yes, it is recommended that you have OpenPlant Modeler running. OpenPlant Orthographics Manager can copy models from stored location and generate orthographics drawings in stand alone fashion.
OpenPlant Orthographics Manager supports multiple view types. Users can create two or more views in one drawing area. Besides multiple views, OpenPlant Orthographics Manager also supports composite view drawings as well as views defined within other views. For more details on this, please see the help file with the product.
Yes, OpenPlant Orthographics Manager supports dynamic views stored in the dgn. You can also select MicroStation Hidden Line mode from project settings to select iso-metric views to create general arrangement drawings.
No, currently this facility is not available. There is no direct process to use OpenPlant Orthographics Manager for PlantWave from PDS models. However it can be done by converting PDS data to OpenPlant Modeler format and converting its DGN to it. In future user could be able to use I-model based files from PDS to use it in OpenPlant Orthographics Manager.
No, Currently OpenPlant Orthographics Manager does not support. However it is expected to get the functionality soon in near Future.
Also See Help File Menu or ReadMe File to known limitation, Whats new & other Local Information.
