| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Component | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
When placing 90 degree long or short radius reducing elbows in OpenPlant Modeler, it gives an error "No Component Found from Initial Spec" even though the Spec contains the reducing elbows with EC_CLASS_NAME as PIPE_ELBOW_REDUCING_90_DEGREE_LONG_RADIUS.
When we check the PIPE_ELBOW_REDUCING class in the schema, there are only two classes defined in custom attribute called "OpenPlant_Physical_Placeable_Child_Classes". Please see below snapshot:
As per this definition, reducing elbows with only above EC Class names can be placed in OPM even if the PIPE_ELBOW_REDUCING_90_DEGREE_LONG_RADIUS exist in the spec. So we need to add the other classes in here so that LONG and SHORT radius elbows can be placed as well. Follow the procedure below to make the changes:
