| Product(s): | OpenPlant Reporting | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | - | ||
| Subarea: | - | ||
| Original Author: | Rahul Kumar, Bentley Product Advantage Group | ||
In OpenPlant Modeler, below explanations illustrates on generating reports for multiple component class.
During Reports generation, user requirement is to extract a report which includes Multiple classes such as Gaskets, Bolts, Piping Components, Supports etc. User need to query the report using Search dialog tool. Below steps illustrates on how to add the component class and then to show inside the report. It can be experienced using both OpenPlant Reporting product or through DGN reporting inside the OpenPlant Modeler.
See Help Menu for additional information.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
