| Product(s): | Promis.e CONNECT Edition | ||
| Version(s): | 10.00.XX.XX to 10.09.XX.XX | ||
| Environment: | NA | ||
| Area: | Power Platform Support | ||
| Subarea: | NA |
Users might want to use the ESC button to exit out of the currently active command.
1. In the Project Manager select Settings >> User >> Preference.
2. Next in the Preference dialog select Input >> check the "ESC exit command" option >> Select Ok.
| Original Author: | Satish Saptasagar |
