| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Modeling |
| Subarea: | Stair Placement |
| Original Author | Sandip Kar, Bentley Product Advantage Group |
This document will explain how to place Concrete stair and also will explain the options inside that Stair tool.
Stair tool can be found via Concrete > Concrete Placement > Concrete Stair
To Place stair you need to select two points. If you need to align with the main structure, it is better to have one predefined line or guide line, so that you can easily place the Stair.
Please note that stair will be placed with reference to selected points or line at center of flight.
After placing the Stairs dialog box will open up to adjust various parameters according to your need. And below are the explanation of the various options to adjust.
