| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7/8 (64 bit) | ||
| Area: | Component | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
This article will explain how you can change the weld size as per your requirement. By default the weld size for metric project is 5mm.
In case, the weld size is modified in the middle of the project, you might need to update the size of existing welds in the model. To update the existing welds in the model you can apply this key-in command "bmech rebuild all" which will update all the welds in one go. Please see below one example.
After execution of 'bmech rebuild all'
