| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Components | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
User complained that when branching off a pipe from small segment of header OpenPlant can't place the Olet/Tee instead it tries to place the elbow. As shown in below picture program is trying to place an elbow on 200mm piece of 100mm header pipe when user tries to branch off from it.
If length of header pipe is less than minimum length required i.e. twice the O.D of header pipe then it doesn't place the olet or tee on the header. So if we take header of 100 mm as an example whose O.D. is 114.3mm.
As per 2 x O.D. formula it needs more than 228.6mm length of pipe to place Tee or Olet.
