| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Components | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
Currently, when we try to connect a small bore pipe to a large bore pipe, Openplant automatically places a concentric reducer. But if user want to place eccentric reducer through auto-fitting what are the changes required will be discussed in this article.
