| Product(s): | ProConcrete | ||
| Area: | Concrete Placement | ||
| Subarea: | Beams | ||
This section contains the wikis related to the Beam Concrete Placement tool in ProConcrete CONNECT Edition. This tool used to create rectangular, circular, and user-defined beams and can be accessed under the Concrete workflow > Home > Concrete Placement > Beam.
Key-in: PROCONCRETE PLACE BEAM
