| | Applies To | | |
| | Product(s): | ProSteel 3D Professional | |
| | Version(s): | 08.11.11.55 | |
| | Environment: | Windows 7 64 bit | |
| | Area: | General | |
| | Subarea: | | |
| | Original Author: | Steffen Knoll, Bentley Technical Support Group | |
To open ProStructure files in pure MicroStation without a PS Plugin the ProStructures drawing
can be converted to a native solid drawing.
- Make a copy of your model.
- Start the convertion to solid drawing.
In Connect edition:
- Options:
One body per group - not recommended - group objects will be melted to one oject
Keep resolution - the shapes will be converted as they are displayed now
- box not ticked - resolution with all arcs will be used
delete Converted - the original ProStructures objects will be deleted or only hidden
Keep Layer - the level assignment will be kept
- After the conversion all objects will be native MicroStation solids
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
