| | Applies To | | |
| | Product(s): | OpenPlant Modeler | |
| | Version(s): | 08.11.09.xxx | |
| | Environment: | Windows 7 (64 bit) | |
| | Area: | Component | |
| | Subarea: | - | |
| | Original Author: | Harpreet Singh, Bentley Product Advantage Group | |
Problem Description
During PSDS conversion, LAP_JOINT_STUB_END does not convert from PSDS Spec to OpenPlant Modeler Spec.
Steps to Resolve
- Launch Class Editor from start menu.
- Open OpenPlant_CustomAttributes.08.11 by navigating to folder \\WorkSpace\OPModeler\schemas.
- Again open OpenPlant_3D.01.06 by navigating the project folder.
- Supplement this with two schema’s OpenPlant_Catalogue_Supplemental_Mapping_PSDS.01.06 & OpenPlant_3D_Supplemental_Modeling.01.06 schema.
- Go to LAP_JOINT_STUB_END class.
- Right click on LAP_JOINT_STUB_END class and add 'PSDS Class Map' custom attribute.
- Add values in the custom attribute as shown below.
- Save the changes in schema and open mapping database file from \\%Project Root%\Dataset\Mapping Databases\ folder as highlighted in below snapshot.
- Add new mapping in MAPPING_INFO table as highlighted in the below picture.
- Save the changes in mapping database and re-launch spec gen.
communities.bentley.com/.../27126.gaskets-not-converted-from-psds-spec-to-openplant-modeler-spec
Comments or Corrections?
