| Version(s): | All | ||
| Area: | ProStructures Licensing | ||
| Subarea: | N/A | ||
| Original Author: | Roger Belen Product Advantage Group | ||
ProStructures Licensing.
This page is for various scenarios that you might encounter with licensing ProStructures.
Bentley’s ProStructures is the combination of ProSteel & ProConcrete. With two products in one installer you would need to have a valid license for either ProSteel or ProConcrete or both.
Also ProStructures use AutoCAD or MicroStation as a base platform to run it. You would need to have valid license for AutoCAD from Autodesk and MicroStation from Bentley depending on which platform you want to run this.
Below are links of Various Scenarios when Activating ProStructures.
Activating Installed ProSteel with AutoCAD as Platform (Deployed)
Activating Installed ProSteel with AutoCAD as Platform (Deployed) version 08.11.11.87
Activating Installed ProSteel with AutoCAD as Platform (Hosted)
Activating Installed ProSteel with AutoCAD as Platform (Hosted) version 08.11.11.87
Activating Installed ProSteel with AutoCAD as Platform Node lock
Activating Installed ProSteel with MicroStation as Platform (Deployed)
Activating Installed ProSteel with MicroStation as Platform (Hosted)
Checking ProStructures/ProSteel License settings (AutoCAD and MicroStation)
ProStructures SS6 License Type Changes
ProStructures SS6 Licensing from Version 08.11.11.45 to 08.11.11.55
Warning - Selected function isn’t available with current license level
