Introducing a set of tutorial videos where we are giving you the opportunity to get familiar with the product and learn ProStructures specially to those who are very new in this software. This is a complete guide where you will learn ProStructures, starting from modeling to documentation, and enable you to design your model, up to the finished product and finally get your 2D detail drawings.
This is designed in such a way, that on boarders can easily get acquainted with the product and gradually learn the workflows. This set of videos comprises both Steel and Concrete tutorial guide explaining both ProSteel and ProConcrete.
ProStructures On-board Video Guide
List of Videos
01: Download and Install |
https://youtu.be/zMWw80gnT1M?list=PLN8aDaF_4kBOoprahHKLUbbGEuyS9Im5h |
| youtu.be/gNbZzKSS9XA |
02: Create a New Project |
03: Basic Steel Modelling Framework |
youtu.be/j69n3FAO1S8 |
| youtu.be/8ZSBfj8lQBE |
04: Placement of Connections |
05: Structural Steel Objects Placements (Stair/Handrail/Ladder) |
youtu.be/zXhwVatxZ28 |
| youtu.be/yrUbAMePpUw |
06: Positioning of Structural Steel |
07: Partlist Creation for Steel Elements |
youtu.be/1NZuFe7alhQ |
| youtu.be/h_OgwAunoe0 |
08: Creation of General arrangement and 2D Fabrication Drawings |
09: Basic Concrete Modelling (Beam/ Column/ Pad Footing/Slab) |
youtu.be/D3jCAm5KdyA |
| youtu.be/cB4OrftvPlE |
10: Concrete Reinforcement (Beam/Column/PadFooting/Slab) |
11: Positioning and Adding Bar Marks |
youtu.be/pFbymisb4eQ |
| youtu.be/-zV-UQs2iPQ |
12: Publishing Bar Bending Schedules |
13: 2D Drawing Creation |
youtu.be/-UTmon0Iywo |
| youtu.be/pTpxh-LmdsM |
14: 2D Annotation and Labelling with Delimiter Settings |
15: Export to IFC |
youtu.be/uar-cPrb74c |
| youtu.be/iDQaPaaqaPY |
16: Publish to 3D PDF file |
Parent topic: ProStructures For Beginners
Download Links:
