| ID | Title |
| 230927 | [Configuration Variables] Modify Catalog Paths -> Edit mode -> Append and Prepend doesn't work correctly |
| 252074 | Destination attribute position on cable diagrams |
| 252280 | [Forced Routing] enable Unforce for wire potential and potential group |
| 253374 | Project Publisher: the name of the packing list created by the Project Publisher is misspelled |
| 307890 | Memory Leak I Possible Memory leak while using different functions |
| 311617 | [Open Page] Open page reports error when add one LCM custom attribute that assigned to Wire property Name of Current |
| 477193 | [PW integration][Environment]Shows "Internal Error" when try to open read-only page from Project Manager |
| 516510 | [Navigation] user defined modes are missing from navigation |
| 522420 | [Wire Diagram][Terminal Symbol] terminal number attributes missing and not populating with correct values |
| 527335 | [PW Catalog Manager]Delete a category, it popups unexpected dialog. |
| 535355 | [Insert Symbol By Name] Fail to list catalogs added in Modify Catalog Paths with Edit mode Append/Prepend while Insert Symbol By Name |
| 537759 | [Network Workspace][Rename Project] Rename one network project that has been opened one page by another user will report error |
| 538898 | [Page Format Designer] It reports error when extract page format from the demo projects |
| 548942 | [Configuration Variables] The user is not able to select WorkSet files in Configuration variables in Managed WorkSpace with PW |
| 570805 | [Forced Routing] new function to allow user to unforce all connections in project |
| 576971 | [New Project] An error appears when create a project under path defined by Add a network location |
| 577159 | In correct terminal numbering on wire diagram |
| 579263 | [Create Symbol]Create a symbol without device id, and then insert it, copy it, the CPs are not correct. |
| 579461 | [Run Graphical Plan]It popups error dialog when place script for some special terminal in the DEMO project. |
| 583176 | [Grid/Snap Settings] Grid value in Design File settings not maintained if Enable Grid/Snap Lock option is unchecked in options |
| 583548 | [Project Manager] Page preview is not updating |
| 587866 | Symbol Graphics not Saved |
| 596767 | [Wire Link] Wire Link's symbol text attribute cannot work properly |
| 597173 | [Place Symbol Again] Error Message while using Place Symbol Again for Symbols without Device Tag/Installation / Location |
| 597758 | [Page Management][Copy Page] Copy multi pages from one project to another project will occur error |
| 601962 | [Update Project Database] Project Database cannot be updated using UI |
| 613121 | [Restore Project] The database is not compatible when we try to restore a project to a database in another server instead of the Default Project Database one. |
| 613417 | [Find-Replace Wire Property][Performance][PW] It takes about 4 min 50 sec to open the Find-Replace Wire Property dialog in large project |
| 613682 | [Terminal/Pin-Plug Manager]It should have a vertical stroll bar in the left side if there are many terminals. |
| 613683 | [Terminal/Pin-Plug Manager][PW][Performance]It is too slow to open Terminal/Pin-plug manager and click Apply button after add cable in the terminal/Pin-plug manager dialog. |
| 613686 | [Performance] [PW]Rename Project is slow. |
| 613745 | [Wire Manager][Performance] It takes more than an hour to make a force connection of wire in the Wire Manager in large project |
| 613962 | [Project Publisher][ProjectWise] It reports exception about access pltcfg file during publishing in PW project. |
| 615579 | [Copy&Move Objects][Copy page][Performance] It takes long time to copy multi objects and copy 3D Layout mode page |
| 615624 | [Delete Objects] [Performance][PW]Delete multi 3D objects will takes long time |
| 616480 | [Update Wiring Diagram][PW][Performance]It is slow to open update wiring diagram dialog. |
| 617420 | [Performance][PW] Modify Project is slow. |
| 617723 | [Rebuild Project Database] An error occurs when rebuild Project Database |
| 617967 | [Page Copy][Forced Routing] new option to all user to Maintain all Forced Connections during page copy |
| 627531 | [Backup] When a Project is backed up the Devinfo table details from Project DB are not present in the ECADProject.mdb file in the PRJ backup |
| 631211 | [Title Block Designer] Options to select the Seed file before creating / editing a Title Block |
| 633768 | [Page Copy][ProjectWise Integration] Illegal characters in path error appears for certain pages when user attempts to copy page |
| 636805 | [Raster Manager][ProjectWise Integration] When a Page containing Raster TIF image attached is closed and reopened in raster manager the TIF file cannot be seen |
| 645218 | [ProjectWise Integration][Configuration Variables] The user is facing the issue that if the Promise.cfg file contains the complete path for ProjectWise location of the configuration file |
| 645434 | [Project Options][Command Protection] - Exposing Parts Database 'Show Differences' to all User Roles |
| 646144 | [Catalog Manager] Getting UI error while rebuilding catalog |
| 646416 | [Configuration Variables][Workset] paths in dialog do not match paths in Promise.cfg |
| 646418 | [Configuration Variables][Workset] changing path value changes values in Workspace tab |
| 652856 | [Performance] Promis.e doesn't release memory after closing page. |
| 660036 | [Manage | Wiring Manager] Unforce Connection doesn’t work. |
| 662092 | [Restore Project] Error message during project restore due to bad data in LCM_GraphicalObject table in database |
| 667972 | [Memory leak]related with traversing selection sets. |
| 680354 | [Project Manager]Imported drawing is blank |
| 680363 | [Restore project] It cannot restore project from PW folder successfully for the second time |
| 680390 | [Create Project] Create project will report error when fill out an non existent Project database |
| 681907 | [Options][Display Formats][Cross Reference Format] Expression do not work due to variable translation. |
| 681909 | [UI] The size of some control is too small to display the whole content. |
| 682053 | [UI][Draw Ladder] The width of the dialog for setting the space between ladder lines is too small to display the whole caption. |
| 682064 | [EDC] The text of ‘Orphaned Balloons’ in the Error Checking dialog is not localized. |
| 682342 | [Report template designer] the attribute is not getting properly align |
| 682517 | [Wire Diagram][Wire Number Attributes] value not updated when user deletes wire number from schematic |
| 684891 | [ Symbol Cross Reference] Symbol cross reference visibility cannot be turned On/Off using Show Cross-Reference option |
| 684942 | [Part Part Number Attribute] When the user updates symbol text the Part Part Number attributes disappears |
| 686241 | [Memory Leak] Opening and closing results in extra processes running in Background |
| 689888 | [Wiring Manager]The default wire potential tree view display is not correct. |
| 690542 | [Wiring Manager]Force routing a connection, and clicking apply, then click OK button to close the wiring manager dialog, and reopen it again, the connection is not forced. |
| 690553 | [Wiring Manager]Change the capital “Want” and “Unforce” to lower case letters “want” and “unforce”. |
| 693509 | [Balloon Number Attribute] When the user updates symbol text the Balloon Number Attribute on NamePlate symbol disappears |
| 693538 | [Restore Project][PW Integration] When user tried to overwrite an existing project in a project wise path using restore project the database details are not overwritten |
| 699964 | [Copy Page] It reports error to copy page in some projects |
| 701148 | [Settings][User Preferences] enabling Compress File On Exit option causes application to Not Respond when user switched from one page to another |
| 701492 | [Wiring Manager]The potential group order should display like 1, 2, 3 … 11, should not like 1, 11, 2. |
| 701507 | [Create Symbol]Modify terminal number, it cannot display in the drawing. |
| 701519 | [Run Report]After force routing, the gauge and color cannot display in the wire list report. |
| 702086 | [Wiring Manager Unforce Connection]Sometimes the unforce connection cannot unforce all the connections in the potential. |
| 702266 | [Copy Page Maintain Forced Connections]Sometimes the forced connections display not correct in the copied pages. |
| 703049 | [Installer] Failed to install |
| 703166 | [Wiring Manager][Force Connection]Force several potential, and click apply button in the wiring manager dialog, some of them are not forced. |
| 706960 | [Wiring Manager][Add Device]Add device in the wiring manager dialog, it popup error dialog when clicking Apply button. |
| 709306 | [Open Page] DGN File name is changed to lower case when exported to PDF / Displayed |
| 709942 | [Wiring Manager][Add Device]Add device in the wiring manager dialog, close the wiring manager dialog, and reopen again, the wire number does not display in the wiring manager dialog. |
| 711516 | [Insert Cable/Bus] Placement by Path Method |
| 713723 | [Wiring Manager] An error occurs when opening the Wiring Manager in large Project |
| 714568 | [Device Usage Chart]Right click the Device Tag->click Device Usage Chart, it popups error dialog. |
| 714586 | [Wiring Manager][Performance] It takes about 3 min 09 sec to open the Wiring Manager dialog in large Project |
| 716141 | [Configuration Variables] Allow user to set the variable assignment level as Workspace and Workset level. |
| 721679 | [PW Integration] Crashing due to background process |
| 726268 | [Navigate][User Preferences] After set "Reset Pop-up menu" to Click in Preferences dialog, Navigate menu will list on the top of right click menu |
| 726605 | [Insert Macro] Insert Macro “STR_MACRO” will crash to the desktop |
| 728751 | [Copy Page] Equipment properties and wire tag in the copied page do not match the details from the source page |
| 729740 | [Project Builder] It reports exception during creating project to include option item. |
| 730001 | [Copy Objects] Copy objects will crash in the demo project |
| 730701 | [Project Builder] It reports Page Error after we click Create button. |
| 731424 | [RebuildProjectDatabase] An error occurs when run the Rebuild Project Database for user project |
| 732820 | [Device Usage] incorrect I/O Address and Function Text values displayed in device usage chart |
| 732916 | [PLC Address and Function Text] plc child address and function text values do not match parent values after using Device Usage to change child position |
| 733161 | Slow performance of Switch the page |
| 733648 | [Performance] [New Page] Open New Page dialog and the 1st time New Page is obviously slower than that in the last release. |
| 734470 | [Copy Page][Copy Circuit] An error occurs when copying a circuit on copied page |
| 735620 | [Navigate][PW]Navigate from a new created mode to another new created mode, and then navigate back, and navigate back again, the software will crash. |
| 737052 | [Thematic Manager] The created Thematic does not work after clicking the Apply button. |
| 738784 | [Configuration Variables]Fail to list Path in Create Catalog dialog for default WorSet, ANSI-IEEE Example and IEC Example |
| 738891 | [Memory Leak]The memory increased after running MVBA in MicroStation. |
| 739425 | [PW Explorer Plug in] An error occurs when copying a page with symbols/wires from PW Explorer |
| 744028 | [Copy page][Copy circuit] It reports error or crash when copy some circuit on the copied page |
| 744288 | [Wire Diagram]Create wiring diagram symbol, defined it Parent CPs, and add Wiring Number attributes, It pups error dialog when update the wiring diagram page with this symbol. |
| 744955 | [New Page]The page description cannot display in the drawing using default workspace. |
| 748882 | [Install] Fail to install due to failing to install Microsoft Visual Basic for Application 7.1 |
| 757020 | It reports unexpected warning during launching software due to wrong Page Templates setting. |
| 757096 | Certify the latest ProjectWise Explorer release 10.00.03.453 |
| 760389 | [Multi-DB]The software will get the wrong project database if we reference a page from another DB server. |
| 763011 | [Start Software] It failed to restart software |
| 767868 | [Symbol Create Wizard][Place Connection Points]Clicking Place button reports error. |
| 771067 | [Restore Project] Cannot restore some user projects |
| 774887 | ConfigurationManager.GetVariable() function returns NULL |
| 774930 | [PW]After office update, the cannot launch correctly when connecting with PW. |
| 776249 | [Modify Page]In the Modify Page dialog, deselect the toggle “Place title block in sheet model”, it should popup warning dialog. |
| 776771 | [Insert Objects] [Symbol Settings] Click Symbol Settings in Insert Symbol/ Macro dialog reports error |
| 805305 | Add the variable _USTN_CLOSE_DESIGN_CHANGINGFILES = 1 in promise.cfg |
| 807028 | [Shortest Distance Routing] [PE Project] The software will automatically be closed when executing the Shortest Distance Routing onuser project |
| 809405 | [Ribbon] Display commands and mode type show wrong |
| 811317 | Can't load Project Manager properly from drawing view after we click File > Close |
| 823097 | [Project Management] After draw a wire without targets, switch page with wire link reports error |
