| Product(s): | OpenUtilities Substation | ||
| Version(s): | 10.08.XX.XX to 10.12.00.XX | ||
| Area: | Installation_Configuration | ||
| Subarea: | N/A |
The purpose of this document is to indicate the compatibility of various software with OpenUtilities Substation CONNECT. It is not intended to describe the compatibility of the various software with each other. For example, certain versions of SQL Server may not be compatible with certain operating systems. Always check the documentation of the various software involved.
| OpenUtilities Substation CONNECT Edition | Update 12 (10.12.00.60) | Update 11 (10.11.00.22) | Update 10 (10.10.00.20) | Update 9 Refresh 2 (10.09.02.23) | Update 9 Refresh 1 (10.09.01.20) | Update 9 (10.09.00.10) | Update 8 (10.08.00.34) |
| Operating System | |||||||
| Windows 11 (64-bit) | Yes | No | No | No | No | No | No |
| Windows 10 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Windows 8.1 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Windows 7 (64-bit) | No | No | No | No | No | No | No |
| Windows Server 2019 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Windows Server 2016 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Windows Server 2012 (64-bit) | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Windows Server 2008 R2 (64 bit) | |||||||
| Database Software | |||||||
| SQL Server 2019 (Inclusing Express) | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* |
| SQL Server 2017 (Inclusing Express) | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* |
| SQL Server 2016 (Including Express) | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* | Yes* |
| SQL Server 2014 (Including Express) | Yes* | Yes* | Yes* | Yes* | Yes* | ||
| SQL Server 2012 (Including Express) | |||||||
| ProjectWise Integration | |||||||
| ProjectWise CONNECT 10.00.03.453 | Yes | ||||||
| ProjectWise CONNECT 10.00.03.434 | Yes | Yes | Yes | Yes | Yes | ||
| ProjectWise CONNECT 10.00.03.334 | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.329 | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.299 | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.280 | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.271 | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.262 | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.167 | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| ProjectWise CONNECT 10.00.03.140 | No | No | No | No | No | No | No |
| ProjectWise CONNECT 10.00.03.49 | |||||||
| ProjectWise CONNECT 10.00.02.320 | No | No | No | No | No | No | No |
| ProjectWise CONNECT 10.00.02.265 | No | No | No | No | No | No | No |
1* Limited support. Tested with Windows 7 SP1. In Windows 7 SP1, Backup Project, Copy Project (to another database) and Move To Database functions do not work. This is resolved in CONNECT Edition Update 1.
2* Requires Windows 7 SP1 Operating System.
