| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.xxx | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Component | ||
| Subarea: | - | ||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
During PSDS conversion, all gaskets do not get converted from PSDS Spec to OpenPlant Modeler Spec. After running the exchange spec, only few gaskets are converted which are also triplicated. STOCK_CODE is assigned to each gasket which is a unique identifier.
communities.bentley.com/.../13021.how-to-convert-psds-catalogspec-to-openplant-format
