| Product(s): | ProStructures (ProSteel) |
| Area: | ProSteel Options |
| Subarea: | Display tab |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
Workframe and Object View Centered commands are not visible in shaded mode. These are visible only in wireframe display mode.
1) Open the ‘ProStructures Global Settings’ from the backstage of the application.
You can also access this by right clicking anywhere in the empty space of your model and select the ‘Options’
2) Select the ‘Display’ field and then switch ON the ‘Workframes when Shaded’
3) This will then display the Workframes in any of the shaded display modes
4. And we can also use the Object View Centered commands as shown in the below snapshot.
