| Product(s): | ProStructures (ProSteel) | ||
| Area: | Tutorial for first use of ProSteel | ||
| Subarea: | Workframe and Navigation tools | ||
| Original Author: | Steffen Knoll, Bentley Global Technical Support | ||
| Updated By: | Vyanktesh Nama, Bentley Global Technical Support |
This wiki explains about the various Workframe settings.
1. If the dialog has been closed it can be reopened via the Structural Properties. Select Workframe bubble, hold right mouse click for 2 seconds, choose Structural Properties (or Dubble click on grid bubble).
2. On the second tab Views, you can find settings for the view frames.
a. Which views frames will be created and how they are named.
b. The view depth for the view frames for later navigation
c. Name of the Workframe, also prefix for all view frame names.
3. Next Tab > Text X:
a. Naming of X axis grids.
b. Dynamic: it is recommended to use this option as the axis names will be visible in most of the view directions.
4. Next Tab > Text Y:
- Same settings as Text X except of numerical instead of alphabetical.
5. Next Tab > Options:
a. Lock Level: The level for the view frames will automatically be locked. This prevents from moving or deleting view frames by accident.
b. Text Scale: Use this field to change the size of the displayed axis names instead of changing the single values for Text X and Y.
