| Product(s): | ProStructures (ProSteel) | ||
| Area: | Tutorial for first use of ProSteel | ||
| Subarea: | Workframe and Navigation tools | ||
| Original Author: | Steffen Knoll, Bentley Global Technical Support | ||
| Updated By: | Vyanktesh Nama, Bentley Global Technical Support |
This wiki explains how you can access the view frames using Select View tool.
1. Under the Steel workflow, navigate and left click on Select View button located at View > ACS View > Select View.
2. To call a view double click on the view name. To keep this dialog open, please switch off the option 'Double click closes dialog'.
3. To view the Front View, double click on the Bentley_Y_1 view.
