| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Settings/Attributes | ||
| Subarea: | |||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
By default, server tree hierarchy is imposed on active tree of Item Browser in OpenPlant Modeler. This hierarchy enforces the items in the DGN tree to be grouped under their respective parent node such as Service & Unit as shown below.
This can be changed to group the components under their respective classes. There are different ways of achieving this in different versions which are listed in next section.
Settings in 08.11.09.440 & lower versions
Settings in 08.11.09.568 & higher versions
In the latest version this setting is changed through configuration variable in OPMS.cfg file which is located in C:\Program Files (x86)\Bentley\OpenPlantModeler V8i\OpenPlantModeler\config\appl folder.
For Standalone mode
Note: This will be a project specific change i.e. project where this variable is defined will have disabled server tree hierarchy.
For Managed workspace
In the CSB properties add new variable in the configuration tab.
