| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.581 | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Component | ||
| Subarea: | Graphics | ||
| Original Author: | Rahul Kumar, Bentley Product Advantage Group | ||
To apply slopes on a pipeline with Socket Welds type fittings in OpenPlant Modeler.
In OpenPlant Modeler, user tried to apply slope on a pipeline, which contains fitting type as socket weld elbows. This converted the fittings to butt weld type elbows or sometimes remove the elbows. See images below.
Pipeline with SW fittings:
Pipeline without fittings when slope gets applied:
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../12009.component-openplant-modeler
Bentley's Product advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
