| Product(s): | OpenUtilities CONNECT Edition | ||
| Version(s): | 10.12.XX.XX | ||
| Environment: | NA | ||
| Area: | Component Features | ||
| Subarea: | NA |
The users some might need to draw cable in 3D layout Mode which might be complex and difficult to draw using Insert Cable with 2 points and Sag. In this article we will see how a B-Spline can be used to be converted into a 3D Cable.
1. Draw a B-Spline in the 3D Layout mode as per requirement which will act as center line for the Cable.
2. Click 3D Design >> Insert Substation Objects >> Select the Part Number needs to be assigned to a Cable >> Insert.
3. In the Placement options dialog select Method: By path >> Specify the Level of the cable >> Select the B-Spline by giving a data point.
| Original Author: | Satish Saptasagar |
