| Area: | Global Settings/Options | ||
| Subarea: | N/A | ||
This section will describe the wikis related to Global Settings or Options of ProStructures CONNECT Edition. This is used to enter the standard settings for several functions.
It is accessed from Backstage > File > Settings > User > Global Settings as well as from the context menu by holding the right-click mouse button and then clicking on the Options menu.
Links | |
