| Area: | PS Toggles | ||
| Subarea: | N/A | ||
| Original Author: | Vyanktesh Nama, Bentley Global Technical Support |
This wiki explains how to enable ProStructures tooltip from PS Toggles and its usage.
1. Go to PS toggles.
2. Turn on Enable ProStructures tooltip toggle.
NOTE: Enable ProStructures tooltip option can also be turned on from Global Settings (Options) > Snaps page.
Usage of Enable ProStructures tooltip:
When this is checked on, it enables the display of tooltip comments on snaps. The tooltip is context sensitive and can be configured by editing the …\prg\tooltips.ini file from the ProStructures installation folder.
For more information about ProStructures Tooltip, please follow the below wiki links.
