To Provide Annotation on Components based on Property Value-v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.09.XXX
Environment:Windows 7 (64 bit) & Others
Area:Settings/Attributes
Subarea:-
Original Author:Rahul Kumar, Bentley Product Advantage Group
To provide Annotation on Components based on Property Value.
Problem Solution
Switching Property value should annotate accordingly.With a new Property, user wanted to control set of Flange, gasket & bolt to toggle ON/OFF on isometrics. Below are the steps to resolve such case using rep_sortgroups.txt file present inside the project style folder.
Steps to resolve
  1. In class Editor, check for a property which is defined control Toggle ON/OFF. Say B_COMPLETE property.
  2. Define this property under Piping Component Class.
    Note - To create a new property under the class, user should refer related wiki present under Plant community.
  3. Launch OpenPlant Modeler.
  4. Assign property value based on Completion of project and are required to show it in Isometric labels & in BOM.
  5. Navigate to Style folder & rep_sortgroups.txt file.
  6. Open Rep_sortgroups.txt file and add below entry to it.
    SORTGROUP = FLANGE_1
      HEADER = @ -----------
      HEADER = @  FLANGE_1
      RULE = IE_TYPE=CT_FLANGE
      SKIP = 1
    SORTGROUP = GASKET
      HEADER = @  GASKET
      RULE = IE_TYPE=CT_GASKET && B_COMPLETE = NO
    SORTGROUP = GASKET_1
      HEADER = @  GASKET_1
      SKIP = 1
    SORTGROUP = BOLT
      HEADER = @  BOLT
      RULE = IE_TYPE=CT_BOLT && B_COMPLETE = NO
    SORTGROUP = BOLT_1
      HEADER = @  BOLT_1
      SKIP = 1
  7. Launch OpenPlant Isometrics Manager & verify results.
communities.bentley.com/.../12638.modifying-text-and-annotation-settings
Comments or Corrections?
