| Area: | PS Toggles | ||
| Subarea: | N/A | ||
| Original Author: | Vyanktesh Nama, Bentley Global Technical Support |
This wiki explains how to enable ProStructures Legacy Snaps from PS Toggles and its usage.
1. Go to PS toggles.
2. Turn on Enable ProStructures Legacy Snaps toggle.
NOTE: Enable ProStructures Legacy Snaps option can also be turned on from Global Settings (Options) > Snaps page.
Usage of Enable ProStructures Legacy Snaps:
When this is checked on, it enables snapping to centerline points at the start, middle, and end of steel shapes along the same dividing point set by the keypoint snap. This option is disabled when Enable ProStructures snaps is checked on.
