| Area: | PS Toggles | ||
| Subarea: | N/A | ||
| Original Author: | Vyanktesh Nama, Bentley Global Technical Support |
This wiki explains how to enable ProStructures Snaps from PS Toggles and its usage.
1. Go to PS toggles.
2. Turn on Enable ProStructures Snaps toggle.
NOTE: Enable ProStructures Snaps option can also be turned on from Global Settings (Options) > Snaps page.
Usage of Enable ProStructures Snaps:
When this is checked on, it enables snapping to ProStructures insertion points. These are ten cardinal points at start, middle, end of steel shapes, concrete beams, and concrete columns.
ProStructures Snaps, which will magnet to the points shown here switching between them using the keyboard arrows. They will magnet to the start and end points and any of the closet points along the length of the object according to the Keypoint Snap setting (enabled with the “K” key).
