| ID | Title |
| 260621 | [Merge Tool]The circuits with balloon cannot be merged. |
| 260632 | [Merge Tool]Merge circuits with Wire Link, it popups unexpected dialog. |
| 432004 | [Delete Project]Creating a project with a page having reference, and backup the project, then delete the project, it popups unexpected dialog. |
| 432594 | [Project Manager] Pages cannot fresh after switch from Favorite tab to Local Folder or ProjectWise in Project Manager |
| 522712 | [Work Order Manager] It should deal with the Work Order name with prefix space correctly |
| 537866 | [Update Wiring Diagram]Updating wiring diagram pages, It popups error dialog in some special condition. |
| 553076 | [PW Integration][Update/Refresh Page] When update or refresh one closed page and keep another page opened, it prompts check in twice |
| 602313 | [BOM Manager] Click the revision node under Work Order will report error in BOM Manager with user project |
| 613415 | [Re-Sequence Wire Link][Performance] It takes about 2 min 50 sec to open the Re-Sequence Wire Link dialog in users Substation project |
| 715343 | [Performance][Move] It’s slow to move 3D Objects. |
| 715346 | [Performance][Copy] It’s slow to copy 3D Objects. |
| 727238 | [WireManager] Unhandled exception occurs when close the Wire Label Preferences dialog in Wiring Manager dialog |
| 728021 | [Modify Page][Multi Project Database] Modify page reports error on two different database projects |
| 728030 | [Symbol Text] After modify I/O text, many hidden symbol texts will show on the drawing |
| 729865 | [Balloon][BOM Manager]Modify a balloon’s values inserted by device in the Modify Balloon dialog, and then select another balloon value, and then only the last selected display in the drawing. |
| 738089 | [PW Integration] Ecad.dgn file should be removed from PW project |
| 738787 | [Insert Cable/Bus Object] It reports objects placement option not cable's placement option during draw cable/bus |
| 740640 | [PW ][Catalog]The initial catalogs loaded in the Catalog Manager don’t same with that in Modify Catalog Path after switch launching software from local to with PW. |
| 741136 | [PW Integration][BOM Manager] After edit symbol text, symbol's balloon will be missing with user projects |
| 744085 | [Auto Backup]It should give a detailed information in AutoBackup.log file for a project missing required file or database connection. |
| 745709 | [PLC Text] Internal Error message when adding apostrophe to PLC I/O text which has family assigned |
| 745900 | [New Page][Title Block Sheet Model]Create a page with toggle of Place title block in Sheet Model turned on, modify the page description, the modified info cannot display in the sheet model in time. |
| 747700 | [PW Integration] Project Path is not updated in database when a folder is renamed in PW Explorer that contains Substation Projects |
| 748268 | [PW Integration] Custom Page Attributes value updated via PWExplorer cannot be seen in Substation page properties |
| 749184 | [CreateCatalog_PW] DeviceDB Error Message: Could not find file 'xxx\Catalog.mdb' appears after create a catalog and create a page by default |
| 754430 | [AutoBackup]The AutoBackup.log file logs the details of folders that are not project folders as Invalid project path |
| 763032 | [Merge Tool]A page is activated, the attach button cannot work correctly. |
| 763967 | [SQL Server] When SQL Server is down or not available Promis.e should give correct error message indicating the issue |
| 764454 | [Multi-Language MDB] Multi_language MDB is not changed When active workspace is changed if switching between projects with different workspace |
| 775523 | [Title Block] When Title Block is placed in Sheet the page descriptions are not updated in title block after they are saved |
| 775581 | [Modify Page] For page with Title Block placed sheet the modify page dialog cannot be accessed by right click on the title block |
| 781211 | [Cable Manager] An error occurs when opening Cable Manager in user project |
| 792089 | [BOM Manager] It cannot update quantity immediately after remove devices in BOM Manager |
| 792099 | [Options]Validation Prompts ->Prompt for saving page when switching pages doesn't work well and an error appears |
| 792718 | [Create Symbol] Symbol DGN not created when new symbol created using Import Symbol Graphics method |
| 800533 | [Macro] When Macro is created using 3D symbols some symbols can be viewed only in wireframe mode display style |
| 800623 | [Balloon Number] Balloon Number cannot be seen in construction drawing when the balloon number is located in Parts Database |
| 800969 | [Configuration Variables] ELEC_CATALOG_PATH Level is automatically changed from WorkSpace to WorkSet after copy a catalog and click OK in Catalog Manager -> Modify Catalog Paths |
| 806331 | [Modify Page]Page descriptions details are not updated in title block if title block is placed in sheet model when page is open |
| 815307 | [Multi DB][Insert Symbol] Insert symbol reports error after switch project with different DB |
| 847749 | It reports error to select some page(s) of users Project |
| 848735 | [Copy Page]The part number is incorrect after copying panel layout page and wiring diagram page. |
| 848763 | The software crashed to select all 3D objects through Ctrl+A in a page of a user project. |
| 848819 | [Ribbon] Display commands and mode type show wrong - Copy |
| 855017 | [Catalog Manager] When switching to a project associated with different workspace then current the catalogs list in Catalog Manager are not updated accordingly |
| 861517 | [Sub ID]It cannot popup the expected EDC dialog when inserting a symbol with more than two sub ids in panel layout/wiring diagram page. |
| 862139 | [Display Part Numbers]The part number cannot display in the drawing. |
| 862255 | All Cross Reference goes to the left down corner of the drawing. |
| 863609 | [Balloons] balloon callouts display incorrect Balloon Number values after user edits balloon number |
| 863646 | [Balloons] balloon callout graphics change position after user makes edits to Balloon Numbers |
| 865676 | [Replace Symbol] connection point order not always maintained when user executes Replace Symbol or Update Symbol |
| 868408 | [Page Copy][Wire Link]Cross Reference / ID text position on copied page does not match source page |
| 870866 | [BOM Manager]Manage->click BOM Manager, it popups error dialog using the default workspace. |
| 871021 | [Catalog Manager] After rebuild catalog, the categories in the catalog are missing. |
| 871043 | [Catalog Manager][Create Family]Create a new family, it cannot be saved in the catalog. |
| 872781 | [Create Symbol]Modify a symbol, add cp, and place the added cp, it popups error dialog. |
| 872786 | [Catalog Manager] Copy a catalog to the catalog path, it cannot list in the catalog manager. |
| 874064 | [Symbol Create Wizard][Place Connection Points]Clicking Place button reports error. |
| 874067 | [Create Macro]Manage->create macro->It cannot call out the create macro dialog using the attached project. |
| 876097 | [Symbol Create Wizard] Insert Symbol in ‘Specify Device ID’ step reports error. |
| 876498 | [ PW Integration][Project Manager] Click Thumbnails in Project Manager reports error with PW project |
| 877215 | [Insert Substation Objects] it popups error dialog when inserting a 3d object with the toggle of “Use balloon numbers from parts database”. |
| 880979 | [Delete Page] After a page is deleted the details associated with Balloon Callout that were present on the page are not deleted from the dbo.SymbolBalloonGroup table in Database |
| 884530 | [Insert Substation Objects][Placement Options][Cable Method] does not function properly when cable symbol is created using Shared Cell option |
| 885059 | [Wire Sizing] It occurs error to use wire sizing feature. |
| 885153 | [Project Manager] Project icon cannot be updated with open page and close page |
| 885799 | [Copy Page][Wire Link] Wire link ID in copied page cannot match source page |
| 885815 | [Project Manager][New Page] Create new Wiring diagram page occurs crash in the attached project |
| 889656 | [New Project] It reports error during creating project after launch Promise at the first time. |
| 889750 | [Copy Balloon]Sometiems the copied balloon callout inserted by Device is not correcet. |
| 889778 | [Orphaned Balloon][Move] Move Orphaned Balloon will crash |
| 890303 | [Copy Balloon]There is a unexpected Orphan balloon record after copy pages with reference files. |
| 890396 | [Copy Balloon]The details info are not correct if the device has more than two part numbers. And it lost the revision number info. |
| 893910 | [Balloon by Device] Modify/Move/Delete balloon placed by device two times report error |
| 897082 | [Wire Link] wire link cross-referencing not working properly when user is using ProjectWise Managed workspace |
| 897252 | [Re-sequence Wire Link]There are duplicate records in the Re-sequence Wire Link dialog. |
| 897963 | [Autobackup] autobackup stops and waits for user input with Alert Message "The project will be updated to new version" |
| 897968 | [ProjectWise Integration] rename one or more folder in project path causes Alert Message "The project will be updated to new version" to appear |
| 898681 | [Insert Symbol by Device ID]The software will crash if insert all child symbols groups by insert symbol by Device ID. |
| 915902 | [Insert Macro]Create a macro and then insert it in the same page with all options not maintain, the device tags are not correct in the drawing. |
| 923444 | [Sub ID] It cannot popup the expected EDC dialog when inserting a symbol with more than two sub ids in schematic page. |
| 923661 | The General_Cables type of wire drawn by Draw Wire command can’t be seen by default on Single Line Mode page after paste a circuit. |
| 924435 | [PW with Network Catalog][Insert Substation Objects] Multi-Preview doesn’t work in Insert Symbol dialog for 3D symbol. |
| 925820 | [Balloon] Edit balloon no from 3D page side, it cannot update balloon no on construction drawing page |
| 930920 | [PW][AutoBackup] AutoBackup failed for valid PW Project |
| 930939 | [Parts Database] The default displayed parts database is not refreshed according to the selected one in Configuration Variables |
| 933459 | [Project Manager][Delete Project] a different project having same project_id in another Project Database is deleted |
| 934580 | [PW] Fail to launch software with PW with the warning of ‘Common data folder does not exist’. |
| 934710 | [BOM Manager]It popups error dialog when copy/paste device using the User’s project. |
| 935439 | [Memory][Copy Objects] Select some 3D objects and click Ctrl+C will crash |
| 935447 | [Device Properties] A strange EDC appears when click OK in Device Properties after modify Device Tag and select a child for a symbol |
| 935481 | [I/O Text] Fail to update I/O Function Text in Parent chart symbol for the selected Child |
| 936216 | [BOM Manager]Copy the part, the quantity cannot be updated in time. |
| 936983 | [BOM Manager]It popups error dialog when copy/paste device without part no and balloon no using the User’s project. |
| 937883 | [Balloon]Activate the reference file the second time, the balloon callout inserted by activate the reference file is not correct. |
| 939151 | [PW integration][Project Selection] It cannot list pages in Project Manager after restart Substation with pw |
| 940012 | [Create Symbol]Place two created new symbols in the wire, and the wire between the two symbols does not has the from and to information. |
| 945683 | [MicroStation Mode] The WorkSpace and WorkSet are not loaded automatically after launch Substation/Promise MicroStation Mode. |
| 946230 | [Upgrade] [Catalog] The catalog SEL_RELAYS_(IMPERIAL) is missing after upgrading the Substation from U12 to U13 |
| 947123 | [Office update][ Access Database Engine] Start and close software will crash after office update |
| 948300 | [Copy Page]Copy page with terminals to other project, there are some duplicate records in the insert symbol by device id dialog. |
| 957969 | [Rebuild Project] Cannot rebuild project database when the software is closed during the rebuild project |
