| Version(s): | 08.11.09.XXX |
| Environment: | Windows 7 (64 bit) |
| Area: | Component |
| Subarea: | |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
In OpenPlant Modeler, to create a custom component using different facing instead of default Raised/Flat Face facings.
While creating a Custom Piping Component in OpenPlant Modeler, possible selections in Connect Points Facing list are only FLAT_FACE and RAISED_FACE.
Required Facing value can by manually entered by typing it with keyboard. It will be set to that value, recognized and evaluated later when connecting other components to it. But you need to be sure, that same Facings exists in your FACING_VALUE_MAP class and in required specification.
communities.bentley.com/.../27965.how-to-create-a-steam-trap-component-in-openplant-modeler
communities.bentley.com/.../19168.how-to-create-multiport-custom-valve
communities.bentley.com/.../27799.how-to-create-custom-bw-valves-with-nipples-in-openplant-modeler
communities.bentley.com/.../18502.how-to-create-custom-components-from-cell
