| Product(s): | ProSteel | ||
| Area: | Bolt Styles | ||
| Subarea: | Anchor Bolts | ||
In this wiki, we are going to see the correct way to place the metric Anchor Bolts in ProStructures (ProSteel) CONNECT Edition.
1. Open the Anchor Bolts dialog located at Ribbon: Steel > Home > Elements > Anchor Bolts.
2. Select your required bolt style and enter all values. Also, enter diameter value manually.
3. Now, load and select all the required database files for Nuts, Bolts and Washers (It only displays the list of entered diameter value).
4. Then place the Anchor Bolt in the model via automatic by selecting plate or by using 3 points method.
In this way, one can place the metric Anchor Bolts without any issues.
