Applies To | |||
Product(s): | OpenPlant Support Engineering | ||
Version(s): | 08.11.09.XXX | 08.11.11.87 | ||
Environment: | Windows 7 (64 bit) | ||
Area: | - | ||
Subarea: | - | ||
Original Author: | Stephen Morrow, Bentley Product Advantage Group | ||
Changing piping (i.e. adding a isometric break point + reassign isosheets) and republishing i-models causes all supports connections to OpenPlant Support Engineering Supports to be lost. This occurs when i-models are republished from OpenPlant Modeler, reattaching these i-models inside of OpenPlant Support Engineering and then publishing combined OpenPlant Modeler i-models.
This issue can also happen if a referenced in i-model is detached and then reattached.
Workaround
republishing i-model ,run the key-in: besm UpdateRelationships
Comments or Corrections?
Bentley Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
