| Product(s): | Project Packager |
| Version(s): | V8i |
| Environment: | N\A |
| Area: | N\A |
| Subarea: | N\A |
| Original Author: | Brandon Moberg, Bentley Technical Support Group |
This technical video will explain how to package a project to send to another client or technical support. Often times this is needed for project work share or to debug problems that can occur. Project Packager will create a copy of the project and project data. These files are pushed to a zip file created. The data is copied to XML format ready to be unpackaged the same route. Please refer to the video for these details:
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
