Below is the list of issues resolved in ProStructures 2023.
| ID | Title |
| 872817 | Fixed crash when Previews are generated from the Detail Center. |
| 874199 | Resolved issues within the Beam to Beam stiffener connection, grouping of bolts goes with the wrong member |
| 1226941 | Fixed wrong config variable defined in all of the WorkSet CFG files. |
| 1245463 | Fixed issues related to 2D details disappeared upon changing level display from saved view. |
| 1246245 | Resolved issues with steel shape with modification gives incorrect NC output |
| 1246249 | Fixed issues with error while creating a DXF |
| 1257894 | Resolved issues with negative KO values in NC output |
| 1258690 | Fixed issues related to suffix t is appearing in the NC output |
| 1294915 | Fixed issue related to ProStructures crash |
