| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.11.87 | ||
| Environment: | Windows 7 (64 bit) | Windows 8 | ||
| Area: | Structural | ||
| Subarea: | Column Grids | ||
| Original Author: | Rahul Kumar, Bentley Product Advantage Group | ||
In OpenPlant Modeler, to scale the Column Grid Text Annotation to Readable view.
While Creating Grids for Structural placement, the Text appear to be smaller in size and only be seen when user zoom in to it. Below steps will solve this problem by modifying setting under Model Properties dialog.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Check Help File Menu for More details.
