| Product(s): | ProStructures (ProSteel) | ||
| Area: | Tutorial for first use of ProSteel | ||
| Subarea: | Workframe and Navigation tools | ||
| Original Author: | Steffen Knoll, Bentley Global Technical Support | ||
| Updated By: | Vyanktesh Nama, Bentley Global Technical Support |
This wiki explains how one can get back to isometric overview from the any select view or plane view.
Method I: Using Platform Feature
1. Go to the View Rotation menu > Hold Left Click and select the required Isometric View.
2. With this you will get following view:
The Workframe lines are not displaying correctly this is because the view depth via Clip Back and Clip Front are still active.
These can be turned off from the View attributes.
Method II: Using ProStructures Feature
It is recommended to use ProStructures Isometric Overview instead of Platform Isometric feature.
1. Go to the Steel > View > ACS View and here you can select your required Isometric Overview.
Which has following advantages:
- Automatically switches off the view depth.
- Sets the coordinate system back to the world coordinates system.
- Five configurable isometric views available.
