| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.564 & above | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | Component | ||
| Subarea: | Custom Component - Connectivity Checker | ||
| Original Author: | Rahul Kumar, Bentley Product Advantage Group | ||
To fix the Error “Invalid Joint exist between the Component” for custom component in OpenPlant Modeler
While Creating a custom component with Flanged ends, OpenPlant Modeler produces an error while running connectivity checker. See image below.
Below are the suggestion to resolve the matter.
communities.bentley.com/.../20661.errors-logs-messages-crashes-openplant-modeler
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
