To Fix Welds on Olets in OpenPlant Modeler
 Product(s):OpenPlant Modeler
 Version(s):08.11.09.581
 Environment: Windows 7 (64 bit) | Windows 8
 Area: Component
 Subarea: Graphics - Olets-Welds-Placement
 Original Author:Rahul Kumar, Bentley Product Advantage Group
To Fix welds on Olets in OpenPlant Modeler.
Problem Description
In OpenPlant Modeler, on placement of olets with some end type preparation doesnot report welds on pipeline. Below steps help user to attain welds on a pipeline.
Reason
This has been occurred due to non-availability of end prep types on Joint class. See image below.
User need to define all End prep types to avoid such problems. See below steps to resolve.
Steps to Resolve
  1. In class Editor Open “OpenPlant_3D.01.06.ecschema” & Supplement it with below mentioned schema.
    “OpenPlant_3D_Supplemental_Modeling.01.06.ecschema”.
  2. Navigate to JOINT Class.
  3. Under Class Tab, Select Custom attribute “OpenPlant_Physical_JointType_Map” & Check joint type [8].
  4. Right Click on End preparation2 and using “Add Element” option. See image below.
  5. Add all possible End preparation types. See image below.
  6. Save & close Schema.
  7. Launch OpenPlant Modeler, Place component & verify results.
    Note - For Existing Welds, user need to run Connectivity Checker to fix the case.
Still a Problem?
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group.  Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../12009.component-openplant-modeler
Comments or Corrections?
Bentley's Product advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
